Brief Description: Install switches and wire lights
Installed the rocker switches into the panel. They fit the panel cut outs perfectly. Wired the LEDs inside the switches to come on with the cabin lighting. You can wire the switch for the light to come on when the switch is on but this seems of little value for daylight flying. Added a Molex connector to the light wiring so that the panel can be removed without having to pull all of these wires. The switches install from the front of the panel so they have to have the wires pulled to be removed.
