Mounted the GTX-45R in the center stack. The unit is a remote mount but comes with a rack to fit the center radio stack. I installed the mounting tray below the GTN navigator and recessed back an inch or so to prevent the box from interfering with the panel. The sub panel needed to be notched to make clearance in the rear of the unit. Ran out of hardware so it is only temporarily mounted for now.
