Mounted the rack for the GTN-650 in the center sectiion. Getting the front aligned with the dash cutout takes some trial and error to get it flush and square with the dash panel. The GTN is big and heavy so there are 10 screws that hold the rack to the dash assembly. Fit the autopilot head unit above the GTN and it fits well. The Autopilot is quite small and there is no rack for it, the head unit clamps to the back of the dash panel with a built in mechanism.
Also got the wires run for the engine starter button. The master relay and starter relay activation wires are not shown anywhere on the plans so you need to find out on your own which terminals to use. Hint... the master relay needs to have a grounding wire between the master switch and the center lug on the relay. The starter needs a 12v pos lead from the "S" lug on the relay to your starter button (or key switch start position).
