Replaced the governor studs with slightly longer studs from Lycoming. The stock studs barely leave one thread past the nut and even though the Hartzell instructions say one thread is enough, I opted to change these out. Also finished fitting the left forward baffle. This took a small amount of trimming to get it to seat properly. Don't screw this baffle down pemanently yet as you will need to remove it later to fit the snorkel from the air filter to the fuel servo.
