Brief Description: Forward baffles and exhaust fitting
Installed the right front baffle and it fit up very easily. The left front was fitted with the air filter fiberglass framing after it was trimmed and nut plates installed. All pretty straight forward. Added the RTV strips to the back so could not install it until that dries. Moved on the mocking up the Vetterman exhaust so I can fit the throttle and mixture cable mount once I know the clearances. It all mocked up nicely and it fits very well. This is the newest design for the RV-14 and has dual pipes exhausting outside the tunnel which is made for the stock single pipe setup. The cowing will need to be notched for these pipes but will be no big job. The heat muffs will need to be fitted later during final installation
