Brief Description: Fuel flow and some fitting changes
Installed the fuel flow transducer after installing the fittings for the AN hoses. Also replaced the upper and lower oil fittings and the manifold pressure fitting with steel vs the aluminum fittings in the kit. One thing mentioned by my last tech counselor visit was that he thought these fittings in the engine block should be steel on steel vs the aluminum. Ordered some from Aircraft Spruce and installed them.
