Brief Description: Finish engine mounting and tech Counselor visit
Received the missing washers for my engine mounts and got them installed and torqued and cotter pins installer. Moved on to trying to find best orientation for the Airflow Performance FM-150 trrottle body. This can mount in any orientation but you need to make sure the throttle and mixture arms are going to ork with the push rod cable setup. Not sure yet which way is best and it looks like I need a wider offset throttle arm so ordering that tomorrow.
Last night had a nice visit from my EAA tech counselor and we went over a lot of the FWF planning and installation details as well as planning for the placement of avionics boxes and a good going over of the build since last visit. Good feedback and I learned a lot as usual which will help going forward for sure.
