Chris's RV-14A Site
RV-14A
Misc painting and fitting
Misc work on serveral areas and got the rear window lip painted. This will hide the Proseal that is used later on when the window is installed to prevent leaks. Should make for a neater installation when seen from inside the airplane.
Edge sprayed
Masking removed
RV-14A Home
2694
320
Avionics/Electrical
59
320
Final assembly
667
Rear Fuselage
504
