Chris Web Site
Date:  3-12-2009
Number of Hours:  1.50
Brief Description:  HS - mistake with shims
I accidentally match drilled one of the shims to the incorrect spar holes. Luckily there was plenty of spare material so a 3rd shim could be made. Need to take more care with checking the diagrams before cutting material! Pinned the front spar to main and nose ribs
Top shim is now scrap due to incorrect holes
Front spar and rib assembly
