Another good night of progress. Drilled the dread HS404/HS405/HS810/HS814 holes (it was a little less stressful since I had done it on the left side) and drilled the skin to the skeleton.
Next step - test fit everything together, then clean all the parts up for priming/final assembly.
Bad pic.. but these are probably the hardest holes on the horizontal stab.
