Brief Description: Priming and drill trim cable hole
Today I finished priming some parts for the HS skeleton and drilled the hole for the trim cable (manual trim).
I was a little worried about drilling that hole because it's a major part (front spar) and it was with the unibit, but it went fine. I did practice several times on some scrap. :) Cleaned the hole up with and all is well.
