Casey's RV-8 Project
RV-8
Prepared HS404/HS405 - clecoed on left HS skin
After a brief hiatus, finally some progress on the tail!
* Drilled forward flanges of HS-405 ribs to match with HS-404 ribs. May need to re-do one... still deciding - probably will.
* Attached all of the spars and ribs together - match-drilled where applicable. Prepped to test-fit the skin.
* Cleocoed on skin for left horizontal stabilizer -- IT LOOKS LIKE AIRPLANE PARTS!!
Everything matched up pretty well - had to tug a couple places, but now it fits and is straight. Nice!
Next is to match-drill the skin to the skeleton. Hopefully I'll have some time over Thanksgiving to make that happen.
Skin clecoed on - this is the left side of the horizontal stab.
Another shot. You can see the ribs and skeleton somewhat, here. HS-405 (end) is just test-fit.
RV-8 Home
59
54
Shop Misc.
