Casey's RV-8 Project
RV-8
Drilling Front Spar
Tonight I got to work on the front spar. The rear spar is pretty much ready to disassemble, deburr, prime, etc.
I clecoed the HS-710 and HS-714 to the front spar and then drilled/match-drilled the holes per the plans (#30). Went well - no disasters.
Tomorrow I need to trim and bend the HS-710 and HS-714 parts. Looking for some guidance on best methods to do this - I'll try
VAF
HS-710/HS-714ready to be drilled.
HS-710/HS-714 drilled to front spar.
RV-8 Home
59
54
Shop Misc.
