Casey's RV-8 Project
Date:  3-21-2010
Number of Hours:  1.00
Brief Description:  Priming and drill trim cable hole
Today I finished priming some parts for the HS skeleton and drilled the hole for the trim cable (manual trim).
I was a little worried about drilling that hole because it's a major part (front spar) and it was with the unibit, but it went fine. I did practice several times on some scrap. :) Cleaned the hole up with and all is well.
On to riveting!
Trim cable hole
Trim cable hole
