Placed the R/H wing on the trolley and installed it to the fuse with 4 taper pins. Inserted the rear spar bolt. Fiddled around a bit with pushrod allignment to the fuse.
The wing sits level and balanced on the trolley so that it can be rotated up or down to allign spar
pics don't do this easy 5 minute operation justice. The trolley makes things so easy.
A very crowded shed. Less than 1 foot from each wingtip to the walls.
