Phillips Zodiac is FOR SALE
Zodiac 601 XL
Fuselage upgrade
7-14-2010
torque tube support and seat bases
I cut and installed a .040" L angle to each side of the torque tube bearing support plate 6B17-1.
Cut and installed the .040 L angles that go under the R/H seat base each side of the spar inspection hole.
Back side of the torque tube bearing support
The front side where you can see the far side .040" angle installed
R/H seat .040" angles clecoed in place
Zodiac 601 XL Home
710
650 Canopy
Back home
Firewall forward
Fuel system
Fuselage upgrade
Pickup day
Undercarriage
Upgrade
Upholstery
Wings and Upgrade
