Brief Description: R/H drill rivets line to new extrusion and other b
Attached the nose skin to the top surface only and drilled the extra A5 rivet holes between the existing rivets for the lenght of the new extrusion. Removed the nose skin, flipped the wing and did the same proceedure on the bottom. Cut the rectangular hole through the rear spar to accept the mass balance arm. Marked and drilled the skin protection plates to the upper and lower rear skins. Opened up the wing tip access hatch hole that I previously scorred with my fly cutter and deburred the edge. Deburred the main spar extrusion and the top rear skin as the quickbuild guys clearly forgot.
top main spar line
Mass balance arm hole in the foreground and the protection plate in the middle of the pic
