Back drilled mass balance arm to ribs with 3/16 drill to match bolts.
Cut out the hole in the front of the aileron for the balance shaft. Reinstalled the balance to the aileron and back drilled the outer rib to the aileron.
Marked and cut the hole in the rear spar for the balance arm.
