Phillips Zodiac is FOR SALE
Date:  3-7-2010
Brief Description:  new spar extrusion
Cut existing .032 rear top spar bent angle out with a hacksaw. Inserted the new extrusion and marked and trimmed the top front of the rear ribs for clearance.
Backdrilled the 5/32 solid rivet holes through the extrusion using a drill guide to hold the drill bit square. Secured the extrusionb with temp AN3 bolts.
