Drilled out solid rivets from wing spar using the drilling jigs that I made. After removing the rivet heads, I used my rivet hammer with a pin punch installed to drive out the rivets. The 5/32 rivets were easy to remove because the dome head was on the front spar cap. The 3/16 rivets were harder because the dome was on the back spar cap which made drilling and driving out much more difficult.
Most of the solid rivets removed
All of the solid rivets removed without messing up any holes. A very tedious job
