Glued some suede around the uprights that run each side of the spar and in front of the sidewall panels. Reupholstered the centre console kick panels with suede as I was not happy with the look of carpet on these parts. Cut out the side cheeks from the grey suede and matched in the blue marine vinyl cheeks. Added the 6mm foam and muslin and sewed it all together after adding horizontal lines in the suede.
Spar support to the left of photo is overpacked with foam to eliminate hard edges
