Made a jig to make the multi layer seat bases into . The vertical ribs are made from chipboard and the base is 1/8" plywood with sign vinyl overlaid to prevent splinters getting into the foam. ----------------------------------------------------------------------------------------------------------------------------------------------------------
Glued up two layers of blue foam into the jig with contact glue
