Cut out a hatch for the center console inspection hole from som .025". Made some spring loaded catched for each end also from .025" and riveted them on with A4 rivets. Added a 6mm layer of foam and upholstered it with the matching fabric.
I have hand stiched the corners for added security of the fabric during flexing for installation
Hook the front end under, flex backwards in the middle and hook the aft end in and release
The hatch snaps down flat and secure but is easily removed in 2 seconds for daily inspections
