Started out by degreasing the panel again and blow drying with compressed air. Mixed the epoxy primer and let stand for 30 mins for chem bonding, good time for a coffee. Applied two coats of primer. 30 mins later I applied two medium wet coats of paint and then a mist coat for for an anti glare finish with flash times between coats.
A good orange peel finish only happens when you dont want it, so i'll settle for a medium peel
ignition and choke on the left, throttle and carb heat in the middle and cabin heat on the right.
