Installed the AirGizmo's GPS holder between the bracing and drill the mount holes. I had to temoparilly remove the bracing so that I could accurately mark the back panel for the cut out. I should have done this pre fitting the bracing but I forgot. No big deal.
Separated the the two 70mm wide ends from the panel and the lower center ish section that houses the throttle and the carb heat. These parts will be permanently mounted to the back panel
AirGizmo's panel dock for the Avmap Geo Pilot II Plus
My lovely Wife bought me this 90 deg air drill for my B/day last year. Best thing since sliced bread
