Began carpeting the cabin area starting with the firewall. I cut 40mm strips and glued them around the stiffeners. Then made the flate panels by cutting the straight sides first and then pressing into place into the corners to find the other lines. I used spray adhesive to glue the carpet in place.
I then cut some 20mm foil back foam to fill between the chanels foward of the heel support so that the carpet will have a flat surface to lay on. Also glued carpet over the corner gussets on the back side of the heel support.
I must have put this piece in and out 10 times to get it just right
