I made some control stick extensions to allow for the length of the Ray Allen stick grips. I used 25x1.6mm aluminium tube. The inner piece is the same tube with 6mm slot cut into the side wall and compressed and pushed inside the outer extension
The Ray Allen stick grip heads will have a machine screw through its sleeve and into the ally tube
The extension will be fastened by two rivets through the main stick
