I had to make a stand off bracket for the throttle cable retainer because the one supplied on the carby is out of line and put to much of a dog leg in the cable going around the nose gear chanel.
Also fitted the choke cable but it was binding somewhere.
Bracket from 1/8 aluminium
bolted on using the existing holes in the existing bracket with 1 x 1/4" & 1 x 5/16 bolt
Note slight bend in the bracket to ease the dog leg in the throttle cable
