Today I fitted bottom cowl first as per the instructions with clecos and then attached nut plates and tinnerman washers whilst the donut held the front in alignment. Next was the upper cowl which went on fairly easily.
laser line generator lining up the cowl joggle with the batten across the longerons in the cabin
top cowl clecoed on
the other half of the donut sitting in place to check top alignment
