Today I just wasn't with it as I put the right axle stub on and torqued it down and realised that i'd put the caliper bracket under the axle instead of on top of it. A little disgruntled, I pulled it off again, assembled it properly and put it back together and torqued it down. Then scratching my head and wondering what was going on inside of it, I realised I had not put on the fairing bracket under the stub axle. Needless to say, I had to pull it off again to rectify my error. Drank lots of coffee before continuing.
Fitting the bearings
Look closely and you will see I have fitted the inboard fairing brackets under the axel stub
