Cut the front wheel pant in two as described in the photo guides. Added the .025" joint strip with 3 floating nut plates on each side plus I added one each side of the nose leg to pull everything in line. Fitted to the pant brackets on the nose fork.
Fitted nutplates to the main gear pant brackets. Drilled and tapped the R/H axle ,installed the bracket and lockwired the bolts.
Laid a straight edge against the tire and marked 500mm in front and back on both sides to find centers
the holes in the pants to clear the axle nuts is 38mm which leaves about 5 mm clearance
Distance between the bolt centers is 16mm which gives a good amount of meat to the center and the edge
