Made and installed elevator stops from N66 nylon sheet and fitted to the top longerons with A5 rivets. Elevator travel has been limited to 32 degrees up and 15 degrees down as per elevator travel revision recommendation from Chris Heintz.
down elevator stops allowing 15 degrees deflection
