I made up the communications harness for the headsets and mics. I used 22 AWG shielded wire from spruce. Because I have installed a harness plug I have had to earth the shield both sides of the plug.
Revisited the wiring harnesses in the fuse to reorganise them after the carpeting.
headset and mic harness
faww that was close, nearly took off without my plane!!
