I match drilled some pieces of 25 tho to the mounting rivet holes of the side panels from the centre console. In the second image you can see I have installed rivnuts and riveted the braces in place.
mounting braces drilled to match the rivet holes and cut to match the front edge of the side panels
you can see the 5 rivnuts installed to mount the side panels.
