I had to make a reducer for the cabin heat scat tube as the NACA vent in the cowl from Jab USA uses a 2" scat but I used the Jab AUS cabin heater which uses an 1 1/4" scat.
In case your wondering, the mould is a plastic silicon tube with a piece of nylon pressed into the end
