Riveted on front side flashings and made felt washers to go under the hinge pivot bolts so as not to scratch the paint. Took to the rear bubble with the angle grinder to smooth out a few bumps on the edges and then sanded the edges smooth with 120 grit and took the sharp corners off. Clecoed the rear bubble back on ready for masking for application of white polyurethane sealant.
