installed cross link rod and drilled the through bolt for the end actuators. The push pull bars to the the latches had to be redrilled because they were to long from hole to hole. I fitted the return spring and added some plastic copper pipe saddles to support the link rod at the centre. After I have fitted the canopy, I will disassemble and paint these parts.
