I Installed the line fittings the the master cylinders and calipers and then bolted the master cylinders in place. There was no special position to drill through the fuse for the brake lines so I just used an approximate position as per the assembly manual picture.
Pedals are angled back slightly.
I need to locate some clips to hold the brake lines to the rear of the gear leg
