Modified an 8mm flush trimming router bit with a pilot that fits neatly into the hole between the spark plugs. It is designed to take off some of the metal at the bottom of the hole to creat a bigger flat for terminal mounting. Drilled out the hole to 9/64" and then threaded the hole to an 8/32 thread. Crimped the new terminals on and screwed them down.
8mm flush trim router bit bored to accept a 1/8" pilot shaft to increase the flat around hole for cht
This hole was designed by Jab engineers as a cht pickup but a probe was never designed
Threaded to an 8/32 thread. Some engines have had this mod done at Jab factory at customers request
