I had to reinstall the prop extension because a guy that used to work at Jabiru told me to use the incorrect loctite on the bolts. Recieved complementary bolts fro Jab but I had to drill the heads for lock wiring myself.
NOTE. Jab says that lockwiring the hub extension is near impossible but once a few feet of wire has been used for practice, success will be yours aswell.
