Phillips Zodiac is FOR SALE
Zodiac 601 XL
center spar final assembly
Installed the L extrusions to the rear spar section.
Assembled both halves of the center spar and nipped the bolts up for test fit to wings. Returned to the bench and torqued the bolts down.
Solid riveted the two halves together through the top rear rivet line on the top doubler.
Installing the vertical extrusions
Some of the solid rivets were obscured by the vertical extrusions so a little ingenuity is required
I am very happy with the result
Zodiac 601 XL Home
710
650 Canopy
Back home
Firewall forward
Fuel system
Fuselage upgrade
Pickup day
Undercarriage
Upgrade
Upholstery
Wings and Upgrade
