Brief Description: R/H root doubler - nose rib angles
Bolted the root doubler on with AN4 bolts as permitted by Mathieu Heintz. Installed the nose rib 1 & 2 angles to the doubler. Applied torque seal to the root doubler bolts. Backdrilled the top surface holes through the rear spar channel angle.
My Easy Lift wing hoist
nose rib angles all set ready to accept the nose ribs once the nose skin is ready to be reinstalled
Clamped every second hole and drilled inbetween and clecoed as I go
