Installed the static pitot pickup under the wing and installed the wiring for the nav & strobe and the aileron trim. Ran the tubes and the n & strobe wires separately through the lightening holes to the wing root and the trim wires through grommets at the front of the rear ribs by itself. Installed the strobe power supply and the tip combo light. Started tying up the wires.
Pitot static is the cheapy from spruce installed in front of the aileron bellcrank inspection hatch
Ran the trim wires, nav & stobe wires and the pitot static tubes all seperately for extra protection
If the strobe wires short without throwing the breaker, I won't have a run away trim nor lose the ASI
