Phillips Zodiac is FOR SALE
Zodiac 601 XL
l/h wing angles
Riveted on L angles inside the bottom skin.
Removed bellcrank bearing chanel and prefitted the new one.
Spaced bearing pivot brackets slightly more apart to allow for the extra thickness of the bearing and two washers.
I started to cut the chanel with snips but decided to use the bandsaw instaed for an undistorted cut
The new chanel prefitted
Enlarged the top bracket holes to account for the new offset
Zodiac 601 XL Home
710
650 Canopy
Back home
Firewall forward
Fuel system
Fuselage upgrade
Pickup day
Undercarriage
Upgrade
Upholstery
Wings and Upgrade
