Brief Description: Elevator bellcrank centre pivot
I drilled the common holes in each elevator control horns for the centre pivot bearing support. The job was simple enough, however I was concerned when I saw a mis-alignment between the horn torquetubes. After scanning VAF and chatting to Vans, all good, and build on. Quite a common issue.
