Brief Description: Horizontal stabiliser spar construction
The horizontal stabiliser rear spar assembly process was carried out. The #19 holes for the HS-708 main ribs, deburring the VA-146 bearing, priming and riveting, and drilling the #12 holes for the HS-411.
The forward procedure was started up to but not including bending of the reinforcement angles and the spars.
