After long periods of contemplation, I figured the airframe was starting to gain weight, and it was time to get it onto it's legs. THe final fit went well. Another geometry check done. Almost spot-on, will need a wedge shim however. Until the finishing kit arrives (estimated about 12 months from now due to the massive backlog at Vans), I will use casterwheels to make life easy in the workshop.
