I did the final assembly of the parkbrake valve today, and fitted it to the nose locker floor. Good to go. I also need to replace the tailwheel fork support. The bronze bush is cracked. I went to fit the replacement, but the tail wheel spring dimension has changed. So now I am on a loooong backorder list for the old style support. I may need to replace the spring, not sure yet.
