Todays task was to assemble the rear throttle components, and install the pilot's throttle quadrant. This was to locate the path for the connecting rod between the two throttles. The Vans templates were cut out and taped in place, and pilot holes were drilled. They were not all bad, and it was quite easy to get the guide string between the throttles to clear the holes unobstructed.
