Rohan Lloyd from Aeroweld in Boonah Queensland accepted the task to fabricate my engine mount. I could not use the Vans one as they only supply one to suit Lycoming engines, however I am fitting the UL Power 520T. UL Power provided a drawing for a mount they did for a 520iS customer. Hopefully the turbo and wastegate will not intefere with the mount, but time will tell. At the end of the fabrication, Rohan also preserved the tubes internally. He is an excellent welder, and I would highly recommend him to anyone!
